Hi all,
I didn't want to make a forum post but after a few days of trying i need help!
Basically I'm sure I need to reset my Galaxy S2 GT-I9100 to factory settings. Something happened and now it will not charge - yellow exclamation mark and false 100% claims. Here's the deal:
I cannot connect the device to pc for Odin/Kies etc.
Knowing i can enter recovery mode (the standard, stock recovery mode, 3e i believe) i tried to install CWM via SD to see if could somehow save my files- I get
my phone is rooted but i cannot tell you which kernel etc. I did it a year ago to unlock the network and never really did anything with it after that. Maybe I could have unrooted it at one point? How can i check considering my situation?
Anybody have any tips? Or should i just accept my loss
Thanks guys! :smokingsomb:
Edit: The reason i'm doing this is that i'm sure it is not the battery that is the problem. I'm sure it is the hardware or motherboard that's broken. Maybe i dropped it and don't remember or it got wet? I dunno!
- I cannot turn on the phone when it is not connected to charger.
- If i plug it into a charger then it gives me the yellow exclamation symbol along with the empty battery (this is recent, the first few days it didn't have the exclamation point but it didnt charge)
- I can turn on the phone when connected to a charger, it'll turn on and give the "Critical Battery" warning, and i can use it for a few seconds (less than 15) before it turns off normally (not suddenly, with the animation and everything).
- Sometimes the phone will give me 100% readings but do the same when i turn it on.
- I can enter recovery mode (3e)
- I can not mount to PC/Debugging/ Device Not Recognised
e verification failed installation aborted
