Installing CyanogenMod 10 on internal memory?
Is it possible to install it using just internal memory instead of using an external sd card? I've followed the directions in the sticky so I'm running gb but when i go into cwm recovery and try to mount the internal sd it says it cannot mount it. I also tried plugging it into my computer and trying the mount USB storage option but I get an error that says "E: unable to write to ums lunfile (no such file or directory)" Any suggestions? Or will I just have to get an external sd card. Thanks!
