Root Installing Emulator Help
Zmod10
So this is the first time I'm messing around with a rooted device since way back when the ipod touch first came out so please forgive me if I'm a little behind. Well I want to install a GBA emulator on since none of the ones on the market seem to be any good and I can't figure out how to actually make the app usable. I downloaded the app here -http://slideme.org/node/5983/talk- and I'm not exactly sure where to put it. I tried just putting it there on it's own and flashing it but it's not showing up in recovery mode. I searched the website for help but I can't find any instructions on how to install it. I don't know if this helps but I'm using clockwork and I have Rom Manager downloaded onto my phone. I also already had BIOS downloaded from a while back. Please any help would be great
Also I'm dunno if this helps but this is the name it gave me when it was downloaded
"6c17140c-0a98-102d-a134-12313a00d126.apk"
It's a apk, so you need to put it on your sd card, use a file manager & navigate to wherever you placed it on your sd & you should be able to install it, by clicking/touching it, you could also install it with one of the several app installers on the market. Also, make sure you have "unknown sources" allowed/checked (menu/settings/applications/unkown sources).
