Help Installing on external memory..?
ragav777
Hi,
I am using android2.1 , can we install applications on external memory card ?
I googled, found result as its possible on android2.2 , Is it possible on 2.1 ?
i've tried nearly every guide i could find on this but whenever i format the sd card my phone stops recognising the sd card and says it needs to be formatted. help?
you need to partition the card.. like you would a hard disk on your pc...
Apps2SD needs one partition, the "normal" apps keep you music etc on the other partition.
This guide is very good...
[FAQ]GT540 Reference Thread ! - Android @ MoDaCo
(Partitioning is dealt with in section 3. "How to Install Apps2SD to my 2.1 device ?") Read the PDF file it links to, its in bad english but its easy enough to follow.
