Root installing recovery help needed
Is it possible to install a custom recovery on my wife's 4G without wiping everything? I unlocked a couple months ago using the revolutionary method, but do not know what happened to the recovery. She needs to get her phone replaced, and I'm trying to back up her app data.
Welcome to the forums!!!!!!!!!!!
:D
You don't need to wipe anything to install a custom recovery. It is done through H-boot. Instructions are in the rooting for dummies gingerbread edition after root section.
1.download the file. here: PC36IMG_RA_2.3.zip
2.rename the file by erasing the "_RA_2.3" part of the name so that it is only named PC36IMG. make sure not to add ".zip" to the name as windows hides extensions.
3.transfer the file to the root (that means not in any folder) of the sd card.
4.power off (you most likely need to uncheck fastboot. settings/apps/uncheck fastboot.) then press and hold power+vol down.
5.hboot should see the file and select yes to update.
6.select no to reboot because we want to go into recovery and make a nandroid backup.
7.select recovery.
8.select backup and restore and select backup
9. select the first three and wimax. the other partitions do not need to be backed up. always keep one nandroid backup with wimax keys backed up on your computer.
10.now you can reboot.
11.using a file manager of some sort or even through your computer via usb, you should rename or delete the PC36IMG file on your card. otherwise you will be asked to update every time you go to the hboot screen. you do not need that file any more.
