Help Instant Messanger
Budule
I was wondering if anyone knew of an instant messanger app that does a better job of alerting you when one comes in......i installied AIM on my pc (me) and my Iconia (wifey), when she hits me , it's fine and makes a noise and all but when i hit her she cant really hear it and it just has the tiny man down on the task bar......is there one that would pop up on her screen somehow?​
Ok first off, domestic violence isn't going to solve problems.
There are three "volumes" for the Honeycomb tablet, make sure the middle one (Notification is turned on).
I haven't used it extensively, but the free app "imo" is supposed to be decent. It can notify by: notification, vibrate, lights and sound.
Use Gtalk :P It auto logs you in most of the time (in Android systems). Surprised the hell out of me the first time I got an Android device when I started getting hellos on my phone from gmail contacts through gtalk.
I used to use AIM on my Android. AIM for Android sucks and sometimes doesn't even make the notification sound. Then it would deliver the same message 3 or 4 times over an hour. Way too buggy. Gtalk is so much better.
I use Trillian, it will also allow you to keep the same contact list on your PC and your mobile device, plus (if you pay a small annual fee) you get synced chat history and continuous chat across all devices you use it on - I have it on my T-Bolt, personal PC, Mac for work, Iconia.
