Help Instant upload stopped working after new SD card - Help needed
bigabarry
Hi All,
I recently replaced my 16GB SD card with a 32GB card. Instant upload hasn't worked since. I've taken the following trouble shooting steps already.
Signed in and out of the Google+ app
Cleared the cache
Uninstalled and reinstalled the app
Checked that settings were correct and upload was turned on
Checked that it was uploading to my Google Drive rather than to Google+
Ensured that my data connection / Wifi connection were working
I'm running Jelly Bean on the HTC Sensation XE
Any help would be much appreciated.
Thanks guys,
Alan
Hi bigaberry and welcome to Android Forums. I have not used the instant upload so I'm not a great resource. I hope another will chime in. For test purposes only, you might try putting your 16g card back in and see if setting it up again will be a success. If it works, this will eliminate your setup etc and narrow the problem to the SD card. I can't imagine a problem with the card but one never knows.
