You are low on RAM (memory) not storage (SD card). You might need to get rid of apps you don't use to update your other apps. But before you try that go to Settings > Applications manager. Select the apps that uses a lot of memory and you're not currently using, then hit "force stop". Try to update. If you still don't have enough memory, stop more apps. Then try again. If you successfully updated, reboot to load the apps you've stopped. If all else has failed then you just have to uninstall apps you don't use.
-Sent using the power of the dark side
If RAM is not memory, then I'm not sure what memory means.
Sent using the force
