I was getting the same error message. Could not get rid of this error even when I removed a significant portion of my apps. The system info always showed lots of room but the message continued. I think I have blundered on the solution. I have the Nook Tablet which was partitioned and then rooted. Many people have noted that NT comes with Netflix installed and that Google Play continuously wants to updated this app. It seems that if you update Netflix it confuses the system and Netflix is installed on the B&N Partition as well as the portion reserved for other apps. I un-installed Netflix update as well as any apps that come from B&N as well as Google Play so there are not duplicates. Seems to have worked. Worth a try.
Also check to see how many TEXT and picture messages you have. All those go to internal memory. There are apps in Play that allow you to delete messages by age, among other methods. It might help
