Root insufficient storage error, rooted, cwm. Need help.
n00nin
hi I have a samsung galaxy note 10.1 I am rooted with clockworkmod. I am getting insufficient storage errors when downloading list apps. I have cleared the dalvik cache on numerous occasion, also cleared data and cache several times on the Google play store. Any help would be greatly appreciated.
n00nin
Problem with "Insufficient storage available" is laying in stock application installer. It does not recognize external SD card. Never mind where you are installing application from. Devices with pre-installed internal SD card has this error.
If you have rooted device, probably you have installed ROM Toolbox Pro. Go to App2SD settings and set "Auto".
This will solve problem as on my Galaxy Note 2.
If you do not have ROM Toolbox Pro, just check your phone settings or settings in other programs where you think can be set up installation of new application on External SD and change setting from "Install on SD card" to "Auto".
Android developers I hope should fix it soon.
Good luck!
