Leslie Ann
Android Expert
Interface Resource shortage, we have all seen it by now.
What is it?
Ever go to a webpage and it takes a long time to load and you get a "Timeout Error"? What this means is that it took too long to get the page, and it gave up, or "timed out".
Interface Resource Shortage is exactly the same, it took too long to deliver your message (or connect your call) and timed out. However, unlike the web page, if you give it a moment, it will usually re-send it when it can (or let you make a call once connected again).
So why do we see it so much?
Different phones have different time out times, some short, some long. Some just simply do not tell you there was an issue. Someone at HTC decided to make ours short, and when it happens to give us a big error message, instead of just waiting or telling us that it was delayed pr cannot connect. That's all there is to it.
It doesn't help that we have a fluctuating signal, and when that happens, the phone will think it has no network and times out as well for not just text messages, but also for calls.
How do we fix it?
You have four options, arranged from most effective to least effective.
The first and by far the most effective is to change a few things, radios and PRI combinations can extend the timeout and change the error message. Some radios increase signal strength and reduce fluctuations. Unfortunately, while this method really helps, it also requires you to be S-off.
The second method is similar to the first, but only involves a PRI fix. Honestly, if you are going to use method two, just do method one instead. You will get all around better results.
The third method isn't permanent but will last a bit, and that is to refresh your activation. This is done from your phone and doesn't delete any data, it merely tells your phone to check in with Virgin and reset your connection to them. This isn't a permanent solution, it may last an hour, it may last 3 days, but doesn't require root or S-off.
The last method is to simply ignore it.
As mentioned it's really not as big of an issue as people make it out to be. The error message is just telling you it's delayed in a convoluted way.
What is it?
How do we fix it?
