SpecialEd
Member
So the droid has so much resolution, I think it may have thrown off some of the normal Android applications.
Calendar single day view has such small fonts but large hour openings. It looks like you could have three rows of text in each item. I can't find a font option. Or a "day starts" option. Or a row height option. I want to see my whole day, if possible.
Same thing on the main screen. Icons have tons of space between them, but the icon names are truncated. Why not wrap to a second line? Again, I can't find any advanced options for this. Why can't I rename icons so at least they aren't cut off? Or just rename them. Astrid is a silly name for a ToDo list.
The main screen has so much space, but the notification bar is tiny for my fat fingers. Again, no preference for adjusting the size of the notification bar.
And the main screen has unused space at the bottom corners L and R of the applications tab. Can widgets go there? Seems like a good place for a "quick" application button for your favorites. I miss having hardware buttons for direct application access like on my treo.
This could all be done in an update I assume. Maybe there is an app for that that I have not found? Thanks!
