Help Internal and External SD Help
I was wondering if anyone has found a way to select the default save place between the external and internal sd's. Everything is saving to my internal and ive ran out of space on that some time ago and I have a 32 gb that isnt getting any use.
You can use gemini app manager to move apps to your sd card.
