Hi
Since yesterday evening i am having this strange issues.
It all started after i answered a call - i got a notification that USB storage has been removed and it was reloaded. Evertyhing worked fine. Then i recieved another call and the same problem repeated itself.
On the third call it happened again yet this time it did not reload itself.
I tried restarting the phone yet to no avail - i had to do a factory reset.
Everything worked well - as i was isntalling software on my pc all of sudden software installed on the memory card (that would be internal storage) become shaded grey and i couldn't use it - it was telling program does not exist.
I decided to format internal storage. uninstall and install again apps.
Since now things are working yet already 2 i got a notification that memory was removed and it was reloaded again.
Also i installed kies software connected phone to pc - i am going to try and do firmware upgrade - yet when i try to do backup it is getting stuck in preparing for backup.
Not sure if anyone has a similar problem or not - i am fearing some form of hardware failure - i only have the phone for 2 weeks - damn unlucky
