Since a lot of People Having Problem in Internal Memory Space.
By the Heart of Pilipino Pride Man. We Help those who need Help.
Be A Good Samaritan.
Here is the Instructions To Clear/Clean Internal Memory of Android Phones
1. Dial * # 9900 #
2. Select/Click "Copy to SD"..
( this will copy all dump files from internal to SD Card, because all dump files consumes large amount of internal memory) Note: Only Select the "Copy to SD" Be carefull...
And see the MAGGGGIIIICCCCCC internal MEMORY FREE..
. -----You May Experiment to Another Android Phones Using this Instructions------------------By: Donald IT/Support Doha Qatar...Mabuhay Pilipinas.!!!!...
And I HOPE IT HELPS A LOT....!!!!
