Help Internal memory /SD card
kriskan
My Bimmer only detects music stored in the internal memory. I use a micro USB cable to connect it in 'Disk Drive' mode which allows me to use steering controls to play the music. It has the latest 2.2 update. the problem is I can only have up to 6gb of music in the internal memory. But if I can access the sdcard in disk drive mode, I will be able to use full 32 gb of music. I have been searching for the past 2 hours in various forums but cant find any solution. Any help is appreciated.
When I connect using the same cable to pc it shows both internal and sd card as two drives.
Is there any way to default the storage to sd card ? - in other words is there any way to show just one drive(sd card) instead of two? ( I dont mind if I have to disable internal memory)
