From my research and questioning the tech support at Samsung and VZW (I posted some of these screenshot results in my comparison posts weeks ago in this forum and in the LG Revo forum) the DC has 2 GB internal memory, 512MB is allocated for use right now. After the OS takes up it's lion share, that leaves 328MB for App memory usage, based on order of priority it gets eaten up quick. I have asked the question numerous times, maybe a sharp developer or tech can weigh in... When GB comes, can the internal memory be resized??? I am under the opinion there is a way to do this, imagine re-allocating the 512MB to 1GB for hot usage. But I am willing to concede that it can't be done if someone can educate me/us...
get the force2sd app and you can put EVERY app on your phone onto your sd, that clears up a lot of space, just remember, if it's on your sd you can't use widgets.
A trick I've used to get apps to go to the SD card when they kept saying they couldn't is DL Titanium BU,backup the app to it, make sure that the 'load app to SD or external' is checked in TBU,uninstall the app off the phone, then REinstall it from the backup off of TBU. It will then put the backed up app on the SD card.![]()
