Internal memory
Short answer, yes of course. But what do you mean by internal memory. I assume RAM but also the disk space for installing apps has also been referred to as internal memory.
short answer, yes of course. But what do you mean by internal memory. I assume ram but also the disk space for installing apps has also been referred to as internal memory.
i guess i mean disk space. I use the "quick system info " app and it give you readings on all your memory storage and stuff and for memory it lists:
Total:186mb, free:42.06, idle: 2.64mb
Ahh that is the RAM you are refering tool and thanks another fun little tool to have. Yeah you will be fine, even when I run a ton of apps I rarely get lag and usually reboot weekly.
What is the easiest way to check RAM usage? Do I need and app for that or am I missing something in the phone? I see where to check available phone storage, it shows I still havae 80m left. But what about checking RAM?
