internal memory
Turbo1002
Just got this phone and love it. So much nicer than the motion. The only problem with it is the limited internal memory. I can not hold all my apps. Does anyone here have a good way to to improve the internal storage? This would make this phone perfect.
There is no way. Cellphones have what they come with and can't be expanded. Some very few apps can be successfully run from the external SD card, but it really doesn't save much storage, because a link has to be left in internal storage pointing to where the app is.
This fix uses a second partition formatted as ext4 on your SD card and mounts it as your internal storage. I have a 16gb card with a 4gb ext4 partition and this is what I have available for internal memory:
:D
1. Root it
2. partition SD card
3. install Links2sd
I remember a guide on this somewhere. If you want it I can give that to you.
