drexappeal
Extreme Android User
What's up everybody. I was just curious if anybody noticed that the internal storage doesn't come up right away, when you have the phone plugged into a PC via USB.
When I first got the MoPho, both the microSD card AND the internal storage would show up as 2 separate drives. The Internal storage would be indicated as the MOT (E
drive. Now, when I select USB Drive, it only seems to identify the external microSD, but not the internal...well, at least not immediately.
Anybody know if there was a setting added that allows/dis-allows this?
drive. Now, when I select USB Drive, it only seems to identify the external microSD, but not the internal...well, at least not immediately.Anybody know if there was a setting added that allows/dis-allows this?
