Help Internal usb storage
Louis14
I have a Endroid Samsung ace plus
Are all my directories and files (that i view in my file manager) located on my internal USB storage?
I don't spreak about my apps.
Yes that is where your files and user data is kept. There other directories on the device as well but you cannot access them without root permission.
I'm not familiar with ACE
If you have an external sd card, you should be able to see that in a file explorer also (along with internal storage)
I haven't heard the term usb storage...Seems to imply a storage device (such as flash drive) connected to usb (I don't think that's what you meant)
