Will this work with Neat rom mate? :beer:
Nice one. Thanks for your work mate :beer:
Mb5 or Mr5, do i choose the one that matches my baseband?
I got stuck at the samsung splash after the (siyah) kernel splash. Had to do a nandroid restore. Any idea what the problem could have been mate?
Mb5 mate
Ah thanks mate. I have a status/notification bar mod so would that be causing the problem?
This is pretty good, thanks for the effort![]()
Any way you can implement changing the colour of the signal strength bars, silent sign etc?
Some bugs I seem to have spotted as well. When you receive a notification it has the word 'clear' and the symbol for clearing overlapping each other at the same time. Another one is the 'bar' that sits at the bottom of the notification centre when you pull down increases in size when you touch it, unsure if that's a feature tho.
Other than that I like it, nice to be able to change the colour and transparency of my status bar and notification centre on the fly without flashing and reboots :thumb:
