valmirkastrati
I got my Samsung Galaxy S4 (GT-I9500) rooted and installed Android 4.4.2 Cyanogenmod 11, works fine overall, but it has got some issues and i hope you could help me with that, if there is anything to be helped.
1) Battery Life - Even though in the reviews it was told that 4.4.2 Battery life will be longer as usual, in my Galaxy S4, it has been reduced at least 30%. I am using the lowest performances but still...there are times when i go to sleep, let my phone with +50% battery, when i wake up, (no apps running) it is like 14-17%.
2) Call Issues - This is the most annoying one. My phone, before the 4.4.2 worked just fine. Now, when i make calls, they ask me if my phone is in the Loudspeaker cause they hear my voice as being far from the phone. And the other call issue is, after 1-2 mins into the call, it just stops...can't hear to whom i'm talking and they can't hear me. Happens not every time but, in 5 calls it happens 3 times.
3) Camera storage - While in the original version (4.2.2) i could store directly photos from the cam to my SD Card, now there is no option...is there even a way to do that ?
Thank you all for your support.
V
V
