Root [International] Android 4.4.3 "may" cause root problems
ironass
Extreme Android User
I know that some of you don't get out much. So I've repeated this post which appears in the General part of the forum in a thread entitled, "Android 4.4.3 coming soon"...
"This next article by the renowned developer chainfire is not intended to spread doom and gloom amongst you rooters and flashers out there but merely to serve as a warning.
Treat it like Knox Security and KitKat SD card security but without any of the running around like Mike, the headless chicken...
Chainfire foresees rooting problems in upcoming Android 4.4.3
According to the article, it looks as though, once again, root dev's will be busy. Unlike the previous security enhancements mentioned above, this is centred around Android's use of ART, (Android RunTime), instead of Dalvik.
This does not affect un-rooted users.
I think the key thing I read elsewhere was that many root apps will have to change the way they work, this may obviously take a little time :-( otherwise,we should still be able to do the same things etc, but only time will tell
Double poo going too hold fire anyway, wont do anything major for the rest of the year as going to be abroad.
