Root [International] Bootloop stuck on Samsung Galaxy Note II
dch1826
Hi all,
My note 2 is root and it is infected oldboot malware. My phone is stuck in boot loop. I try to reset factory default, flash the new firmware, wipe data, wipe cache...
But not effective.
Please help me to solve it.
Thank you so much
Moved to the root section for better support for you.
Hi all,
But not effective.
Thank you so much
Did you also wipe Dalvik cache?
I try it many times :(
By the way, when I plugged in micro USB, my phone works properly. when I unplugged in micro USB, it will bootloop when using any applications that need to connect Internet, or using camera.
Do you think it's caused by hardware errors?
Sure it could be a hardware problem. The one I've heard about earlier is a stuck powerbutton. What do you mean with "micro USB plugged in", plugged in to what? PC? charger?
Try to unplug it from PC or charger and leave it plugd into the phone, (cable only). If it is ok then, you might have a problem with the USB port on your phone.
Hey man, I am totaly out of any new ideas, the only last thing I can contribut with is, do you have a possibility to try an other battery? When it is plugged into PC or charger it activates the charging, could it be your battery that is saying goodbye?
