Root [International] Bricked my lg d802 i think please help
V
Valiceemo
Guest
i think ive bricked it!
i cant boot at all
LG G2D802
was running CM11 snapshot, i flashed a kernal and when twrp said....reboot nothing
no LEDS on, the screen seems to have some light but nothing, ive tried booting to recovery via power button and volume but it wont
wen i plug it in windows shows multiple external drives that need formatting!?
If you think there may be some light on the screen still, try long pressing the power button to make sure it's entirely powered off. Otherwise you can't use the power/volume buttons to access recovery.
Once it's for sure powered down, try again to access either recovery or download mode. Just to be absolutely sure you're timing the button presses correctly, see this:
LG G2 Recovery and download mode - YouTube
Even if you can't get into recovery, let's hope for download mode at least.
Thanks for the reply
tried this and nothing.
Phone totally off and cannot get to recovery or to download mode
Without download mode, I don't know of any way out. That does indeed sound like a brick I'm afraid. However, if there is an answer out there to fix it, you can find it at freenode IRC, channel #lg-g2.
If you are an old hand at IRC and have a client, great. If not login here:
freenode Web IRC (qwebirc)
Make the username whatever you want and enter #lg-g2 into the box for the channel. Then do the captcha to log on. Those guys have seen it all. If it can be fixed, they'll let you know.
Thanks ill give this a try, im unfamiliar with freenode web irc?!
ok, new development.
Thought id plug my G2 into worek laptop before heading home.,
as ususal a load of drives appear in windows explorer
When i look into that drive E: tghere is one folder, image.
Inside this folder are the following:
Directory of E:\image
07/07/11 14:07 <DIR> .
07/07/11 14:07 <DIR> ..
20/01/14 22:28 12,321,200 modem.b17
20/01/14 22:28 80 tqs.b03
20/01/14 22:28 35,556 tqs.b02
20/01/14 22:28 6,568 tqs.b01
20/01/14 22:28 180 tqs.b00
20/01/14 22:28 334,928 adsp.b10
20/01/14 22:28 180 playread.b00
20/01/14 22:28 776 adsp.b06
20/01/14 22:28 120,364 playread.b02
20/01/14 22:28 2,055,480 adsp.b04
20/01/14 22:28 799,548 adsp.b05
20/01/14 22:28 1 adsp.b02
20/01/14 22:28 5,043,888 adsp.b03
20/01/14 22:28 500 adsp.b00
20/01/14 22:28 608 playread.b03
20/01/14 22:28 107,712 dxhdcp2.b02
20/01/14 22:28 308 dxhdcp2.b03
20/01/14 22:28 180 dxhdcp2.b00
20/01/14 22:28 6,568 dxhdcp2.b01
20/01/14 22:28 6,748 playread.mdt
20/01/14 22:28 120 adsp.b08
20/01/14 22:28 276 adsp.b09
20/01/14 22:28 6,568 playread.b01
20/01/14 22:28 657,312 modem.b18
20/01/14 22:28 73,728 modem.b19
20/01/14 22:28 23,156 isdbtmm.b02
20/01/14 22:28 92,760 modem.b14
20/01/14 22:28 1,213,768 modem.b15
20/01/14 22:28 1,056,468 modem.b16
20/01/14 22:28 12 wcnss.b08
20/01/14 22:28 7,384 adsp.b12
20/01/14 22:28 54,528 modem.b11
20/01/14 22:28 105,176 modem.b13
20/01/14 22:28 7,068 wcnss.mdt
20/01/14 22:28 7,388 adsp.mdt
20/01/14 22:28 6,568 cmnlib.b01
20/01/14 22:28 180 cmnlib.b00
20/01/14 22:28 72 cmnlib.b03
20/01/14 22:28 94,568 cmnlib.b02
20/01/14 22:28 6,568 widevine.b01
20/01/14 22:28 180 widevine.b00
20/01/14 22:28 6,748 cmnlib.mdt
20/01/14 22:28 125,556 widevine.b02
20/01/14 22:28 6,748 mlserver.mdt
20/01/14 22:28 180 mlserver.b00
20/01/14 22:28 6,568 mlserver.b01
20/01/14 22:28 26,524 mlserver.b02
20/01/14 22:28 592 mlserver.b03
20/01/14 22:28 2,558,544 wcnss.b07
20/01/14 22:28 28,976 wcnss.b06
20/01/14 22:28 39,936 wcnss.b04
20/01/14 22:28 126,976 mc_v2.b02
20/01/14 22:28 12 mc_v2.b03
20/01/14 22:28 6,728 wcnss.b01
20/01/14 22:28 340 wcnss.b00
20/01/14 22:28 8,284 modem.mdt
20/01/14 22:28 104 isdbtmm.b03
20/01/14 22:28 180 mc_v2.b00
20/01/14 22:28 6,568 isdbtmm.b01
20/01/14 22:28 180 isdbtmm.b00
20/01/14 22:28 6,748 tqs.mdt
20/01/14 22:28 168 mc_v2.b01
20/01/14 22:28 7,620,520 modem.b21
20/01/14 22:28 5,376 modem.b20
20/01/14 22:28 3,909,264 modem.b22
20/01/14 22:28 179,504 modem.b25
20/01/14 22:28 6,748 dxhdcp2.mdt
20/01/14 22:28 10,084 wcnss.b02
20/01/14 22:28 179,165 modem.b08
20/01/14 22:28 81,920 modem.b05
20/01/14 22:28 7,432,976 modem.b04
20/01/14 22:28 6,374,376 modem.b03
20/01/14 22:28 90,868 modem.b02
20/01/14 22:28 7,336 modem.b01
20/01/14 22:28 948 modem.b00
20/01/14 22:28 6,748 widevine.mdt
20/01/14 22:28 6,888 adsp.b01
20/01/14 22:28 720 widevine.b03
20/01/14 22:28 348 mc_v2.mdt
20/01/14 22:28 6,748 isdbtmm.mdt
20/01/14 22:28 88,372 adsp.b11
20/01/14 22:28 201,792 modem.b26
20/01/14 22:28 84 mba.mdt
20/01/14 22:28 236,400 mba.b00
84 File(s) 53,659,066 bytes
2 Dir(s) 12,451,840 bytes free
Does this help with diagnosing?
I have the exact same problem. Its 14 non accessable drives and E right? Did you solve it? I am frustrated cannot find a way out. Even the Linux way doesnt work. Please tell me how if you got it solved!
Yes. FIghting with that problem for 3 days now. Got the phone new and I am so excited... Cant use it... Hahaha. Hopefully He solved it. I mean he had the problem back in december!
I am originally German. Im an exhange student in Naples, Florida, right now. I have the international D802 unlocked version.
I'm afraid these gents problems may be far more severe. As I understand it, they have no boot, no download mode, no recovery and no fastboot mode.
To me it sounds like a corrupt or incorrectly flashed aboot. And without one of the above options, I don't know how to fix that.
I'm still not sure what all you've done. The reddit page shows a couple different "solutions". If you used fastboot flash and have now lost that with no other means to interface the phone, again I know of no other solution.
Exception being the Linux only solution. But it's specific to your device showing up in windows device manager as qhsusb_bulk. I have fixed one that way but I'm not sure your situation is the same here.
I deleted the mentioned Data from the phone. Wasnt able to flash the new though. After that the phone turned black and never back on no matter what. I tried the linux variation. It does not work. I just tried at in the Visual Mashine though. But still it should have worked. I followed the XDA thread and it should have worked. It is a different case.
I think new op needs the twrp for his device to recover it since the op is in fastboot . just flash the recovery img
via fastboot? I cant anymore. Fastboot isnt recognizing the phone anymore. Nothing does. I tried the Lg support tool, lg pc suite, and fastboot. Nothing
Can we chat somewhere else? Its easier to give proper instructions for you in a better communication. Here its kind of hard. You have facebook? Just for chatting. No need to add :)
I am a noob with android just switched from jailbreaking on the iphone few days back and you can see the results -.-
