Root [International] can i wipe cache ?
dan44762000
i updated cyanogenmod 10.1 on my phone using the built in updater and since then its been a bit laggy and not as fluid .
can i boot into recovery and wipe the cache without loosing any data .
just to give it a bit of a boost .
thanks
dan
Yeah you can wipe the cache and you won't lose anything :)
Do a nandroid backup just in case though, always better to be safe and do it every time you do something to the system
Some may not agree with me here lol but i use the App Cache Cleaner widget from time to time when it gets laggy. I just use it manually. Not automaticly :thumbup:
You won't lose data unless you wipe the /data partition :thumbup:
Wiping dalvik cache and cache is always a good first option when things get wonky
