henricsson
Hi there!
I know this question has been asked before, but I haven't found an answer that works on my phone...
I have a S3 with stock rom from Samsung/provider Telia (Sweden). After rooting with CF Auto Root, the data connection drops like every five minutes and mostly stays off. The airplane mode on/off fix won't work, nor will the "mobile data on/off" in Settings.
The only change I have seen after rooting, when it comes to data connection, is that the SIM operator code and Network operator code used to match (24001). Now, the Network operator code is 24005. (See picture. Some info has been grayed out for privacy reasons, but are all available.)
Does it matter, and does it affect this problem? If so, are there any solution to this which won't cost me a ton of money?
Thanks a lot in advance!
