Root [International] CWM loop :(
CWM loop : (
Please help . i tried to install a rom using cwm recovery system . and now it is not working . keep restarting . anyone can help . i looked in the forum i couldn't find an answer : (
You could try a few things.
1. Head back in to recovery and clear both caches and factory reset.
2. Head back in to recovery and restore the backup you took before you flashed anything.
3. Try flashing the ROM again.
One of them should hopefully sort you out. :)
thank you very much for your response . but i can't go to recovery modd . it just restart again . the only two things i can see is the white galaxy log and ablack circle written below it clock work nide recovery
it keeps go between those two ... i did flash the rom again but the problem is still there.
i can use the downloading mode . : (
