Root [International] cyanogen mod 10.1 on intl s3
dan44762000
i want too put android 4.2.2 on my phone and use cyanogen mod . the only one i can use is the nightly builds .
anyone using it ?
how stable is it ?
bugs ?
thanks dan
Not sure man. I dont see so many CM users on here tbh. Im gona wait on a 4.2 rom based on the official sammy release i think
I see youre a giffgaff man. Do u use the gg forums mate?
have put the nightly build on my phone but now my signal strength is very poor . usually get 3-4 bars in the house but lucky to get 1 on this new rom .
going to go back to stock 4.1.2
i used Cwm to back up my phone ,
quick question when i restore , will it put all my old apps back on there so i dont need to reinstall them all ?
thanks dan
Op - yes i use the giffgaff forums occasionally
Bars aren't representative of anything in particular. The only real way to monitor signal strength is through about device > status
However, since full sources for the International S3 were never released, you'll find plenty of bugs or low performance areas in AOSP roms.
yes i got that same answer in another forum so i tried too make calls and when i could connect it would drop out after a few seconds . sometimes managing a few minutes . (my dad was very understanding) .
but i have now removed it and gone back too stock , where call quality is perfect again and have 3 bars .
4.2.2 is lightening fast though , i could instantly tell the difference in speed of device .
but no photo spheres - although i believe i could have flashed that separately myself .
so is there any Rom out there on 4.2.2 specifically for the s3 or is it a case of having to wait .
thanks
dan
