Root [International] Dirty flash
Imo (lots of people would say NO) try it, play around with it before restoring titanium and see what you think. Use the same gapps.
Really though unless its a step up from the same rom then NO, wipe everything 1st.
Actually im gona tell u to atleast format /system first because PA has so many changes to android over CM.
.......try it... it wont harm but if you plan to keep using it, do a system and data wipe :beer:
Lmao at my flipflop answer ^
Me personally id dirty it, check out the features then if i like it, go back, do a clean flash with gapps and enjoy it.
Think what i was tryin to say is you wont break anythint:beer:
Personally, I've always wiped before going to a different rom. I only dirty flash when going to a higher version of the same rom.
As funky said tho, backup and then flash. You'll probably get a few bugs but you'll see some of the features :thumb:
