Root [International] (Fixed) problems with internet solved!!
Simonna
Hello guys, I decided to flash my second ROM called JellyBeer latest version on my Galaxy S3, my first ROM which I flashed was SuperNexus Build 3 (with no success)
So what's the problems? The biggest problem on these both ROMS was that I couldn't connect to the internet (even if signal was good,I was registered to the network,enabled 3G, and of course it was shown on my signal icon), ok, on the JellyBeer I could connect to the internet only with Opera Mini strange isn't it? Even tried to set up my internet settings again but no luck even if I did all Full wiped+data wipes+dalvik wipe.
Other problem which happened to me only on Jellybeer(based on Android 4.2.2) was Gapps (latest version based on Android 4.2.2) stopped working errors I tried all possible methods which I found on the internet but no luck. Of course I loved this ROM it was very smooth but it's gave me more headache than more satisfaction of it.
I don't know ir it's me such a noob that I can't normally use ROM without problems (like others does) ir it's ROMS problems.
So how's your experiences with the custom ROMS? And maybe anyone know the solution to the network problems on custom ROMS?
BTW when I was bavk to stock ROM all network problems gone.
Hello Simonna:hello:
Could I ask which version of the gs3 you have please? I'll then be able to move your thread to the relevant all things root forum. Other members who hang out there will be best equipped to give you advice on custom ROM's.:)
I have Galaxy S3 I9300 International version.Thanks :)
No problem. I've moved this to all things root.
I've only used Samsung based ROM's so I'm not going to be too much help here but I know others in the forum have used aokp so you should get some help.:)
Im clueless sorry :confused:
If the 3g or H icon was there, the internet should work. Did things like email work? I really dont understand why only Opera Mini would work.
Sorry i hope someone else is more help :beer:
I have a feeling that Opera Mini worked as it has its own ip adress so kind of bypasses the apn settings but no idea why you couldn't connect when you had the 3g symbol as for that to be there the apn settings have to be correct:confused:
Yes, E-mail worked too but my other almost all apps didn't want to connect to the internet and even I didn't got error that no internet connection or something like that, just that adress bar on top couldn't finish to load, it's just shown me that loading,but it's couldn't to complete loading,so I just got the error that it's loading too long and time is over (I forgot that exactly error) And for example on Firefox mobile it's shown me IP error (I forgot what was written there)
Hmm maybe it was really something wrong with IP adress but I don;t understand, I don't use any IP configs,any firewalls.:confused:
Are you using the latest version of jellybear, 4.32 and which version of gapps are you flashing?
No,beofre flashing the ROM called "Jellybeer" I had Jelly Bean 4.1.2 version, and when I flashed this ROM I had latest jelly bean version 4.2.2
And I downloaded Gapps 20130301 version based on jelly bean 4.2.2 version and on CyanogenMod 10.1.x (which Jellybeer is based on this CM version) and I installed Gapps and Jellybeer from official developer's page.
Yeah that's the correct gapps. Did you download the ROM from this page?
It looks like the ROM changed to a different dev in the team so there are two threads. The most recent version is in the link above so if you downloaded from the other page before give this one a try.
http://forum.xda-developers.com/showthread.php?t=1981822
But this ROM only for Google Nexus 4 isn't it? And I've read that you can't flash a ROM based on different phone models (for example flash LG nexus 4 ROM on Galaxy S3 and etc) or you will brick your phone.
And I downloaded ROM from this page based on my GS3 I9300
http://forum.xda-developers.com/showthread.php?t=2346099
Oops sorry wrong link. Same name and same dev. I was supposed to post that link you posted so you're on the latest. At least one of us is awake:)
Could you remove the link from the quote in your post please so nobody flashes it
Maybe trying a different modem might help?
Bit of a strange problem and one which i cant think why it would happen between two different ROMs
Yeah modem is maybe the best thing to try next. I dont get how it will connect for some things and not others though :confused:
Hello again, guys,I found some similar articles about my problem, so in one forum I've read that it can be google services issue, and I had an issue with gapps, which always stopped working, especially when I clicked on "turn on data" and I always had "com.google.process.gapps has stopped working" so probably I got my issue,but I couldn't got how to fix it, I tried to reflash it, to make factory reset, to wipe everything, so probably it was gapps issue not ROM :)
Hello guys, how are you? I tried to flash SlimBean latest Build 7 now, and I have the same issue, if I won't fix it I will finally understand that custom ROMS are abslutely not for me.:(
If openly I feel sad now that I can't use any custom ROM for this problem. :((
Edit: it's what I have got on my stock browser
authentication via proxy server was unsuccessful
How to fix it?
Try going into APN settings and totally remove "proxy" then hit save. It doesnt do any harm n its worth a try :thumbup:
(Maybe take a note of the proxy setting incase you need to put it back)
Oh my God I fixed it now I can conenct to the internet!!!!!!!!!!!!!!!
I love you man, and now I'm so happy!!!!!!!!!!!!
P.S please don't delete this tread, this can be useful for more people and to me too in the future
Thanks again guys, for trying to help me :)
