Root [International] Fun Things To Do When Rooted :)
dynomot
Android Expert
OK, I'll start the ball rolling anybody can add to this. The only thing I ask is if it is dangerous in any way please tell others it could be and why (if possible).
A simple but fun one, change the power up fanfare. This is in no way harmful if you follow my instructions to the letter.
When you power up you get the Samsung logo and tune. Altering the tune is simple, and although I'm sure it has been done before I discovered it for myself.
First find a clip approx 2-5 seconds long, or even better make your own. It needs to be an .ogg file so either make it one or convert it, there are lots of online converters that will do it for you for free.
Now rename it "PowerOn.ogg" - the capitals P & O are important. Then using a file explorer that allows you to view and alter files in your System folder go here :system>media>audio>ui. In there you will find the original PoweOn.ogg, rename it entirely PowerOn.bak, a bak file renders it useless, but keeps it should you wish to turn it back into an ogg file and reuse it. Now either cut or copy and paste your renamed clip into the folder. It will show up in an alphabetical list next to the PowerOn.bak file. Turn off your phone and turn on :) Enjoy!
Incidentally my Note 3 plays the Nokia tune on startup now :)
Should move this to the Android Lounge. Would get more responses and it's not specifically for the Note 3.
BTW I think some of these ideas might be interesting!!
I might change the camera sound to the Flash Gordon song, The part that goes Flash Ahahhhhhh
Pep
