Root [International] Googymax max kernel for GE
How's it looking?
A bit like this:
great so far, slick n smooth. vibration on boot has gone, now works with nightmare gov, and battery seems pretty good so far. and touch wood no audio farting either....
Dan's rom has two versions, the cm and ge. So does googymax. Did you flash the matching versions?
i just download again the GE version from googy. and samething happened with my phone. wont boot up. can you send me a link for the correct kernal for dans rom? thanks
Dan's GE is M9 based. Your probably using the latest googy which is M10+ based
You need to use 1.1.5.
I've also answered you on XDA.
However, on Dan's CM ROM I really do not see the need to use anything but the stock kernel, but each to their own!
thanks for the reply. yes i read youre reply on xda too. im sticking for now with the stock rom :)
New version up.....
[18/11] Version 1.2.0 (TW / GE / CM) :
- tracing/syscalls: combined patches from cyanogenmod
- frandom builtin and activated (say hello to better responsiveness)
- stweaks: use deltas for cpu & gpu voltage control (complete different method)
- cpufreq: remove prevention of managing offline cpus (cpu0 can now rest idle on 384MHz)
- Some patches from 3.18 branch: ARM, zram, mm
- sched: enable ARCH_POWER feature
[20/11] Version 1.2.1 (TW/GE/CM) :
- ramfs: show stock voltage values for CPU & GPU
- Revert "sched: enable ARCH_POWER feature" (battery drain)
- ramfs: collect stock voltage values before settings get applied
- GE: back to normal IR (hopefully fixing IR problems on GPE)
- Some kernel sched patches
Wow, at the speed these bad boys are being released, it's like the good old s2 days:D:thumbup::D:thumbup:
