there is no working one click i think
use this
http://androidforums.com/verizon-ga...ou-go-one-step-unlock-root-relock-unroot.html
you have to follow everything, in order, step by step.
if you do it exactly right, barring a problem like your computer os not being compatible, it should work perfect.
sounds like you messed up in the process somewhere. i used the same method and it worked perfect. my pc is windows 7 64-bit
the programe freeezes and i have to alt-ctrl-del to shut down
