thefletch
Member
Hi obviously I have a rooted gnex I have 2 problems 1 is I cany get my pc to recognise my device? 2 I have got an AOKP and a gummy rom on my fone but when I flash them they install but there is no soft keys so basically I go into an app then Im stuck and have to reboot tell a lie theres a 3rd issue at mo im running liquid smooth v 1.4 but every few hours I get a message saying the UI has stopped and lose my soft keys and my notification bar
just re-installed the samsung drivers problem still persists
sorted the computer not recognising my device by reinstalling the drivers and swapping usb port as for the roms I got riid of the zip files from my fone then downloaded AOKP build 40 & G apps now its running sweet as nut again
SORTED SORTED SORTED SORTED SORTED SORTED SORTED SORTED SORTED SORTED SORTED SORTED SORTED SORTED SORTED SORTED SORTED SORTED SORTED SORTED SORTED SORTED
