[International / GSM] does CWM break wifi?
efApple
Member
I had been rooted since Thursday using the stock bootloader, but this weekend decided to install the CDMA CWM bootloader. This morning when I got into work, I am unable to connect to our wifi network which uses WPA/WPA2 authentication. It gets stuck on "obtaining IP" address. My wifi works fine at home with WEP authentication. I had the same issue with my Droid OG with CWM installed, but I never thought it was CWM that was causing the issue. Any thoughts?
