[International / GSM] Google Play store (market) issue
ankh
OK Ive installed a ROM which is working great but the problem is, is that the market has stopped working for some reason. It loads up for a split second then boom its gone. Tried reinstalling it. Tried re-flashing with a different ROM even tried downloading it from xda. Still not working.
Please help
Sorry Im a noob
I deleted the Google apps with an apk called system app remover. Then install gapps from the web.
Once done that put the gapps file at top of the so card and flashed that with clockwork.
Type in Google how to install gapps
You don't have to delete gapps, you just have to make sure that you flash them with the ROM. Best practice is to flash them immediately after flashing the ROM before reboot.
