thehybridkiwi
Is there is a way of installing custom ROM's without ClockworkMod?
I'm only asking because I'm interested in transparent methods (knowing what's going on) rather than relying on black box packages.
From what I understand, custom recoveries like ClockworkMod are simply feature-enhanced versions of the basic recovery.
All the tutorials I've found for installing custom ROM's seem to require ClockworkMod (dump the zip into the root directory and run the tool). Is there a way to install, say AOKP, manually instead?
On a side note, I just found out right now that booting into stock recovery doesn't work when rooted. Apparently, you need ClockworkMod as your recovery. :\
