[International / GSM] Notification led
tonytouch311
So im stocked rooted and unlocked and I do not have light flow installed, although I have had light flow installed before numerous factory wipes. Everyday, usually while I'm in the car with the phone plugged into the headphone jack, my led shines bright solid red, solid yellow , blinks blue, blinks green or cycles through each color. Only way to fix it is to restart the phone. I have no idea what it may be. I've even shut off led notifications, started up in safe mode and still haven't got a clue. Is light flow somehow lingering somewhere I can't see? Anyone else with this problem?
I can't imagine LightFlow uninstalled would do this based on a leftover folder on the internal SD, but anything is possible!
Did you delete the Lightflow folder from your internal SD? Also check /sdcard/Android/data to make sure there's nothing in there relating to Lightflow.
If you did that and still have the issue, one thing you can do is try the process of elimination. ie; begin freezing downloaded user apps with TitaniumBackup in chunks of 5 apps at a time till the issue stops. This should help narrow down the app causing your problem.
