[International / GSM] [REQUEST]THEME Pre-Release Blue soft keys, blue circle battery, and blue notification toggles
andoird213
Android Expert
Hi all,
I'm wondering if someone could make a theme that includes the pre- release GNex keys, ICS blue circle battery, and ICS blue toggles for AOKP (I'm running build 21). If the soft key colors can't be changed in ROM control like the normal ones can, please make them ICS blue as well! My goal is to have my phone all ICS blue :D . The keys should be compatible with all the mods done in ROM control if you build it specifically for build 21 as it is included in it (in which case you wouldn't have to make them blue I could just change them to it). I would appreciate you trying to generalize as much as you can though in areas other than the mods already included in 21, since I flash every nightly the day it comes out and it'd be awesome if it was future compatible!
Thanks!!
Patriot
