Fabolous
Superuser
This is a generally stock ROM with mods chosen to add to functionality without detracting from the Ice Cream Sandwich experience that Google envisioned. I built this ROM from AOSP, merged in mods from CM9, AOKP, GummyNex, and other ROMS, to create what I feel is a perfect mixture of stock feel and helpful customizations.
I had a lot of fun building, testing, and running this ROM. I hope you all enjoy it as much as I do!
Features
Credits
Changelog
v7-2
(maguro/toro)
v7
(common)
Requirements
Screenshots
Instructions
Things to be aware of
Downloads (redownload if your GPS/Navigation is missing)
full_maguro_IML74K-ota-eng.bigxie.7-2.zip
signed_GAPPS-IML74K-010112.zip
Mirror
5b995a2a5fca29c9b035eb8581790ca3 full_maguro_IML74K-ota-eng.bigxie.7-2.zip
56f817c0b597d8fc797dd28e71225734 signed_GAPPS-IML74K-010112.zip
Extras/Mods
Stock IML74K Kernel w/ charge fix + init.d
signed_IML74K_Kernel_Fixed_bigxie.zip
e603e3665bc22a81ea8050ec1575b042 signed_IML74K_Kernel_Fixed_bigxie.zip
Stock Launcher2 (will delete Trebuchet)
signed_IML74K_Mod_Stock_Launcher_bigxie.zip
5a87a4c7668d7f6682b8c3a1cad42016 signed_IML74K_Mod_Stock_Launcher_bigxie.zip
T9 Dialer - (use at your own risk!)
signed_IML74K_Mod_T9_bigxie.zip
fbd37c398e63ceaa3d022a1c19f6dfac signed_IML74K_Mod_T9_bigxie.zip
Source Code
bigxie -- Bitbucket
If you enjoy my work, consider buying me a beer
Donations FabDroid
Features
- Built from AOSP source code - synced 12/31/2011
- Stock look and feel with useful mods
- Customizeable Notification Pulldown Widgets
- Built in Perfomance Settings (a la SetCPU)
- Rooted and busybox preinstalled
- Facebook sync enabled
- 3.0.14 Apex Kernel built from source, 1.35GHz capable, UV controls
- Advanced Power Menu w/ reboot and screenshot options
- All apks deodexed/zipaligned/optimized
Credits
- Google: for creating ICS and the AOSP
- birdman: for CMDA build, proprietary files help, helping me fix camera effects
- kejar31: helping me with the gapps, APM, auto restore fix, and more
- CyanogenMod: Trebuchet launcher, back button app killer, and more
- paulobrien/romanbb: facebook sync fix
- WJDDesigns: optimized boot animation
- imoseyon: kernel pointers and UV control fix
- jrummy16: Performance settings
Changelog
v7-2
(maguro/toro)
- Fix deep sleep issue (works again)
v7
(common)
- Added notification pulldown widgets (user customizeable, scrollable, removeable)
- Added Performance Settings (ty JRummy16!)
- Added Automatic Brightness settings from CM9
- Added Trebuchet Settings shortcut in Settings
- Default config changes (allow non market sources, speed up transitions)
- Exiting Airplane mode will now turn on wifi automatically (if it was on prior to entering)
- Long Press Back to Kill cleaned up (now will vibrate and display toast message)
- Fixed UI sounds for ICS
- initial support
- fixed Wimax downloading via Browser
- fixed MMS
- changed a wifi channel setting which should help non US and EU users connect
- Fix a bluetooth issue that prevented deep idle
Requirements
- GSM Galaxy Nexus (GT-i9250)
- Clockwork Recovery
- Radio XXKK6 or UGKK7 are recommended for 4.0.3
Screenshots
Instructions
- Wipe data and cache! Just wipe cache and dalvik if coming from build 6 or later
- Flash ROM file
- Flash my GAPPs file immediately afterwards prior to rebooting.
- Reboot
- Profit
- The launcher comes with auto rotation enabled (even though the checkmark is not checked in options. Check and uncheck to disable)
- Facebook picture sync can take a while, please be patient
- Please allow the phone some time to sync initially (calendar, picasa, bookmarks, etc.)
- If market auto restore gets stuck, a reboot should fix it
Mirror
Extras/Mods
Source Code
bigxie -- Bitbucket
Donations FabDroid
