[International / GSM] Rom installion help
ankh
I downloaded aokp 4.2. Every time I install it I get an error with the android guy dead on its back. This happens no matter how many times I download it and install it. I've also wiped everything. I'm installing it through ROM manager
Are you sure you have flashed the latest version of ClockWorkMod recovery? You can do that within ROM Manager.
Also, RM can be the one causing this problem. I've stopped using that app and do all my tinkering right inside recovery.
Well I'm gonna wait till aokp launch it officially. I will give that a try when its released
Running Roman's latest 4.2 AOKP preview. The advice was to flash the latest CWM recovery. I'm using 6.0.1.9 and all has been fine.
