*First Softkey Mod Post*
Just thought I'd share my custom softkeys with everyone
FOR ROOTED PHONES ONLY
INTENDED FOR JELLYBEAN USERS
(It might work on ICS but but I can't guarantee that it will)
TESTED ON YAKJU JELLYBEAN 4.1.1
How to install:
1. Open up root explorer.
2. Scroll down to system, then app.
3. Change from Mount R/W to Mount R/O
4. Search for SystemUI.apk
5. Copy it somewhere
6. Rename the copied SystemUI.apk as SystemUI.apk.backup
7. Move it to system/app
8. Download my SystemUI.apk from the link below. If you're on a PC, move it to the Download folder or any folder you like. If you downloaded it from your phone, open up root explorer, scroll down to sdcard or storage/sdcard0 and go on the Download folder.
9. Move it to system/app and overwrite it.
10. *IMPORTANT* Change the Permissions to rw-r--r-- (Owner - Read/Write, Group - Read, Others - Read). Press okay, then restart your device.
Download Link: SystemUI.apk
How to restore original softkeys:
Delete the SystemUI.apk from system/app and rename SystemUI.apk.backup back to SystemUI.apk. Make sure the permissions are set as rw-r--r--, then restart your device.
Here's how the custom softkeys look like:
ENJOY!
How to install:
ENJOY!
