[International / GSM] Titanium Backup Crashing
JBNex
Everytime I try to backup to XML in TB Pro, it crashes. It happens after I select a choice such as SMS, Call Log, etc. It says Unfortunately Titanium Backup has stopped. I can go to the Restore option fine no problems though.
Hi there JB :)
Did you try the normal fix it methods? ie; uninstall-reinstall or completely wiping it's settings (clear data).
Report back with every step that you've tried.
Hi there JB :)
I tried clearing data uninstalling rebooting reinstalling still FC
Hmm. I had that same problem once before, and for the life of me I cannot remember what I did to fix it. I wanna say that I deleted everything dealing with TiBu from my SD (and backed up the backup file to my pc), but I'm not entirely sure.
You could try booting into recovery and fixing permissions to see if that helps.
If that fails, then try;
Uninstall TiBu (both the regular TiBu app and it's pro key app), then backup the TiBu folder to your PC, then delete that folder from your internal SD. Make a backup also of data/com.keramidas.TitaniumBackup to your PC, then delete it from your internal SD. Reboot the phone.
If that fails, I recommend contacting the TiBu dev. If you do, be absolutely sure you are very specific in each and every troubleshooting step that you tried. This will help him better assist you.
Thanks! I fixed the problem. It was the /sdcard/Android/data/.. TB folder. It wasn't writable and permission denied when deleting it. I solved it by adb navigating to /data/media/Android/data and deleting the folder from there.
Thanks a bunch!
