[International / GSM] trying to relock bootloader
litrekid
Member
Having some trouble relocking the bootloader and wondered if anyone could help. Following the droid-life instructions, downloaded the zip file, using winrar to unzip but when I go through the adb commands it tells me it cant load bootloader-toro-primekk15.img. I have tried putting the whole file in my platform-tools and putting the files in individually but it always says it cant load. Any help would be greatly appreciated.
if you are trying to relock the bootloader all you have to do is vol+/- & power into the bootloader have your drivers installed then fastboot oem lock through cmd thats it
Im in the bootloader. Drivers are installed. your saying that I just have to give the command in cmd to fastboot oem lock?
command prompt on your computer. When you type fastboot devices while connected in the bootloader it should list the serial number of your device if the driver is installed correctly. If it is type fastboot oem lock , done.
Well hell, I thought I had to go through the whole process explained on droid-life. I guess thats if you are rooted. New to all this but Im a quick learner, thanks for taking the time!
