Root [International] HD Widgets Lockscreen?
axes
I have an S3 running 4.1.2 and I also have the latest version of HD Widgets installed and in use on my device. I hear that it does indeed feature lockscreen widgets, but i have no idea how to add HD Widgets to the lockscreen. Please any advice is appreciated.
Thank you.
Welcome to the forum axes:)
Widgets on your lockscreen isn't a feature in 4.1.2. I think it will be added in 4.2 though. If you want to stay official and not go down the custom ROM road you well have to use a third party lockscreen such as widget locker until 4.2 is released.
Thanks a lot for the reply :D
+1
Widget locker is your best option mate. Id recommend not using a pirated version. Im fairly sure it was that app that gave me a virus or something and taught me a lesson. Havnt used a cracked app since :thumbup:
