Root [International] help! deleted play store using titanium backup):
You can use the md5 file under pda, if you doke the instructions in the dummies guide on how to root, but instead of using the file suggested to root, change it with that md5 file you have downloaded.
You shouldn't need to clear anything right now, after flashing it might be worthwhile doing a factory reset, but that's all :-)
But you didn't flash anything before, so the idea is that by flashing stock Rom as identified and downloaded already, this should write over any issues and give you a fully working phone again :-) then if there are any issues after flashing we can look at doing wipes etc :-)
I was looking on you tube and some guy suggested that I delete the hosts file through a root manager and it worked! I've backed up play store using TV haha
Open settings then storage and scroll until u see the google play app , open google play app and press enable ( I haven't tried it but it should work )
