Root [International] help endless boot loop
Hey Friend.. How are you
I thought I should let you know about my issue.
As you've been more helping and All... even 4am you were awake to give me solution.
So i thought you must know what was exactly the Problem was. and Which Was not Available anywhere on the Internet I guess.
Well I was pulling my hair out and done absolutely everything.. Mostly but no use..
I have decided I will only use that custom os otherwise I will not use phone... so for two days my phone was switched off and people are screaming at me. but I have decided..
so last option I was going to apply was use of Fasboot command.. I read somewhere that extract rom zip and blah blah...
so when i went to extract it.. there was an
error on one APK file.
thats it.. I
downloaded same os again and installed it. and It works like charm...
I f ing don't know why
zip file got damaged. but it was. and never had chance for use fastboot. thank God for that I guess.
anyway thanks.. this was it
Bye..
It might be an idea, when restoring from Titanium, to only retore the app, and not the data, especially if you're installing into a different rom. Give that a try and see if things improve.
Edit:- didnt see your last post until I posted this. Glad you got things sorted!!
