Root [International] HELP PLEASE Screen flicker when trying to put into recovery.
Gags111
HELP PLEASE!!
You've all probably heard it a thousand times before but here goes;
After years of reluctance and caution I decided to root my Android device.
I was quite pleased after looking at all the forums and videos at how easy it can be to root your GT-N7100.
I found this link and followed the instructions
How to root Samsung Galaxy Note 2 GT-N7100 (Jelly Bean)
I followed all the instructions. One difference being that when I connected my device the com box on ODIN3 was Blue not yellow but after looking at a few forums the new versions of ODIN display Blue in the Com box not yellow when your device is connected?
I went ahead anyway and afetr hitting start on ODIN the confirmation Box went green and said pass but my phone really did nothing. I was expecting it to boot in to CWM which the instructions stated could take between 5-8 mins to complete.
When my phone turned on it was still the same settings? I then checked that SuperSu was in my app drawer. I downloaded TTB to back up all my settings and also a Root checker(which confirmed I was rooted)
To get into CWM I pressed Vol+,Home key,Power button simultaneously but the screen displayed;
Android System Recovery <3e>.
reboot system now
apply update from SD card
wipe data/factory reset
wipe cache partition
I pressed the power button and the phone turned on as normal?
With the instructions I follwed initially did I put Clockwork mod on my phone?
I then looked at another forum and found a clockwork mod link and used ODIN to put it on my device? should I have done that?
Now when I press Vol+,Home key,Power button simultaneously it wont go into Android recovery or CWM but instead the screen flickers and goes blank? I took the battery out and powered it up and alls fine.
But I want to put a custom Rom on!!!!
1. Should I be concerned?
2. What should I do now?
Anyones help would be very much appreciated.
Thanks:confused::confused::confused:
